TomiTomi írta:Mustang JD írta:Nyitásnál viszont érdekesség, hogy első gombnyomásra csak a vezetőoldali ajtót nyitja, másodikra engedi az anyósülés felőlit is.
Sőt a koraiaknál, ha a második után nyomva tartod a gombot, akkor az ablakokat is lehúzza.
Ez az ablak lehuzas csak az Anti theft.... rendszereknel ervenyes...
Viszont talaltam egy manualt: ebben leir mindent..... viszont en nem vettem eszre, hogy az indexem vilagitott volna barmikor is:D
lehet ez az eu - conversion - miatt van:D
1. Press "lock" and release to lock all the doors. Note: The interior lamps
will turn off (unless the dome lamp control is in the full-up position),
and the turn signal lamps will flash if all doors, trunk and hood (if
equipped with active anti-theft system) are closed and locked. If the
vehicle is not equipped with the active anti-theft system, the turn signal
lamps will flash if all doors and the trunk are closed and locked.
2. Press "lock" and release again within three seconds to confirm that all
the doors are closed and locked. Note: The doors will lock again, the
horn will chirp once and the turn signal lamps will flash once more.
If any of the doors, trunk or hood (if equipped with active anti-theft
system) are not properly closed the horn will make two quick chirps and
the turn signal lamps will not flash. If the vehicle is not equipped with
the active anti-theft system, the horn will make two quick chirps and the
turn signal lamps will not flash if the doors and the trunk are not closed
and locked.
Opening the trunk
Press "trunk" once to open the trunk.
• Ensure that the trunk is closed and latched before driving your
vehicle. Failure to properly latch the trunk may cause objects to fall
out or block the driver’s rear view.
The remote entry system allows you to open the trunk while the ignition
is in any position. However, if the ignition is in the 3 (ON) position and
the vehicle is in motion, the trunk will not open if the vehicle is moving 3
mph (5 km/h) or faster.
Sounding a panic alarm
Press "panic" to activate the alarm. The horn will sound and the turn signal
and interior lamps will flash for a maximum of approximately 3 minutes.
Press again or turn the ignition to the 2 (ACCESSORY) or 3 (ON)
position to deactivate, or wait for the alarm to timeout in 3 minutes.
Note: The panic alarm will only operate when the ignition is in the 1
(OFF/LOCK) position.
