2005-2009 Saleen S281 / S302
Hozzászólás Szerző: TomiTomi » 2007.07.26 23:41
Saleen egy tuning cég, mely saját karosszériaelmekkel teszi egyénivé a GTt. 3 teljesítmény fokozat kapható:
- S281 3V: 335 LEs szívómotorral
- S281 SC: 465 LE kompresszorral
- S281 E (extreme): 550 LE tovább pöckölt kompresszorral
Mindegyik fokozat coupéként és kabrióként is kapható.
Részletes műszaki adatok:
Saleen Inc. írta:SPECIFICATIONS 2007 SALEEN S281 3V Coupe
GENERAL
Curb Weight 4: est 3550 lb
Weight Distribution, F/R: 53/47
Width: 74 in
Length: 189.1 in
Height: 56 in
ENGINE
Type: 4.6L, 3V, SOHC V-8
Horsepower: 335 bhp @ 5200 RPM
Torque: 345 lb-ft @ 4500 RPM
Fuel: Premium Unleaded 91 Octane
Accessory Pulleys: Saleen Underdrive Power Pulleys and SFI Approved Damper
Exhaust System: Saleen Stainless, 2.5 in. Center Exhaust
Intake: Saleen Design Hi-Flow Inlet Tube and Air Box
DRIVETRAIN
Transmission, Standard: Saleen Quick Ratio 5-Speed Transmission, 8.8 in. Differential 3.73:1 Ratio8.8 in. Differential 3.73:1 Ratio
Transmission, Optional: 5-Speed Electronically Controlled Automatic, 8.8 in. Differential 3.31:1 Ratio
SUSPENSION
Front: MacPherson strut with lower control arm; Saleen Racecraft system including N2 struts with linear-rate coil-over springs; 1.38-in. tubular stabilizer (anti-roll) bar with urethane pivot bushings; specially calibrated suspension settings
Rear: Live axle located by three links plus a Panhard rod; Saleen Racecraft system including direct-acting, linear-rate coil spings and N2 shocks; 0.79-in. stabilizer (anti-roll) bar; specially calibrated suspension settings
BRAKES
Power 4-Wheel ABS
12.4 in . Dual Piston Calipers w/ Vented Disc (Front)
11.8 in. Disc (Rear)
WHEELS AND TIRES
Saleen Seven Spoke Alloy Wheels
20 in. x 9 in. (Front)
20 in. x 9 in. (Rear)
High Performance Dunlop Sport Tires
275/35ZR20 (Front)
275/35ZR20 (Rear)
Saleen Inc. írta:SPECIFICATIONS 2007 SALEEN S281 SC Coupe
GENERAL
Curb Weight: est 3356 lb.
Width: 74 in
Length: 189.1 in
Height: 56 in
ENGINE
Horsepower: 465 bhp @ 5800 RPM
Torque: 425 lb-ft @ 4000 RPM
Saleen Intercooled Supercharger: Saleen Series VI Integrated TwinScrew Supercharger With Two-Stage Water-To-Air Intercooler System; Cast 356-T6 Aluminum Alloy Constructions
Exhaust System: Saleen Stainless, 2.5 in. Variable Exhaust
DRIVETRAIN
Transmission, Standard: Saleen Quick Ratio 5-Speed Transmission, 8.8 in. Differential 3.55:1 Ratio
SUSPENSION
BRAKES
Saleen ABS 4-Piston Calipers
Saleen 14.0 in. Slotted & Vented Disc (Front)
WHEELS AND TIRES
275/35ZR20 (Front)
275/35ZR20 (Rear)
Saleen Inc. írta:SPECIFICATIONS 2007 SALEEN S281 extreme Coupe
GENERAL
Width: 74 in
Length: 189.1 in
Height: 56 in
ENGINE
Horsepower: 550 bhp @ 6100 RPM
Torque: 525 lbs-ft Torque @ 4900 RPM
Crankshaft: Special Saleen Forged Steel
Connecting Rods: Saleen Forged Steel
Pistons: Saleen Forged Aluminum
Saleen Intercooled Supercharger: Saleen Series VI Integrated TwinScrew Supercharger With Two-Stage Water-to-Air Intercooler System; Cast 356-T6 Aluminum Alloy Construction
Radiator: Saleen Performance dual-core radiator and high flow cooling system
Calibration: Saleen PowerFlash™ performance calibration
DRIVETRAIN
Transmission: Saleen Quick Ratio 6-Speed Transmission
Differential: Saleen 4.10:1 Maxgrip™ Differential
Clutch: High performance clutch
Flywheel: Light Weight Aluminum
Driveshaft: Balanced Aluminum
SUSPENSION
Springs: Saleen specific rate front and rear springs
Struts: Saleen front struts (N2)
Shocks: Saleen rear shocks (N2)
Control arms: Boxed lower control arms
Axle: Three link live rear axle panhard rod
Front : MacPherson strut with lower control arm; Saleen Racecraft system including N2 struts with linear-rate coil-over springs; 1.38-in. tubular stabilizer (anti-roll) bar with urethane pivot bushings; specially
BRAKES
Saleen ABS 6-Piston Calipers
Saleen 15.0 in. Slotted & Vented Disc (Front)
WHEELS AND TIRES
Saleen Forged 5 Spoke One Piece Wheels
20 in. x 10 in. (Rear)
Ultra High Performance Pirelli P-Zero Rosso Tires
275/35ZR20 (Front)
275/40ZR20 (Rear)
A hozzászólást 1 alkalommal szerkesztették, utoljára TomiTomi 2009.10.11 16:57-kor.
Hozzászólás Szerző: TomiTomi » 2007.07.26 23:44
Érdekes opció a Saleentől az üvegtető. 8)
Hozzászólás Szerző: TomiTomi » 2007.07.26 23:52
A Saleen S281 extreme a Transformers filmben is szerepelt.
Cikk hozzá a Saleen honlapján.
Ez előre vetíti az új extreme modellt, az S302 extreme-et.
Saleen Inc. írta:Press Release:
(Saleen.com) The cars are the stars in DreamWorks’ new hit movie “Transformers,” and the Saleen S281 Extreme is receiving rave reviews as everyone’s favorite bad guy. Appearing in various scenes, the Extreme – disguised as a deceptive police car code-named “Barricade” –pursues lead character Sam Witwicky, played by Shia Labeouf, and ultimately battles his “Autobot” protector, a 1976 Chevrolet Camaro named “Bumblebee.”
Saleen delivered multiple S281 Extremes to the “Transformers” set for filming, but none were equipped with the new Saleen supercharged 302 cubic-inch engine of the soon to be released 2008 model. Debuting in late-summer 2007, the new Extreme is expected to set a new benchmark for performance vehicles in its class. Designed by the same engineering team as the Saleen S7, the new Extreme will be the first vehicle to deliver true super car performance in a production sports car.
“Fans of the movie can see the Extreme police car on display at The Saleen Store in Irvine, California,” said Mike Simmons, chief marketing and sales officer of Saleen Inc. “What’s even more exciting is they can actually purchase the production model from their local Saleen certified dealership, without the police badging and vicious alter-ego, of course.
The 2008 Extreme is a limited production vehicle of only 200 units and a waiting list is already starting. However, we have two more attainable S281 models that have the same body style as the “Barricade” car. They might not destroy ‘Autobots’ as easily, but they are plenty fast and fun to drive.”
About the 2008 Saleen S302 Extreme
As the headliner of Saleen’s “S” model line, the 2008 S302 Extreme will boast a redesigned and supercharged version of the company’s highly acclaimed and potent 302 engine introduced in 2007. Although official specifications are still under wraps, the new powerplant will produce well in excess of 600 horsepower.
This new Extreme model will replace the current 550 horsepower model. The S281/S302 model line also includes the 335 horsepower S281 3-Valve, as well as the 465 horsepower S281 Supercharged. All three S281/S302 vehicles share like styling cues, but each maintains its own personality, driving dynamics and performance elements.
Exact specifications and performance ratings for the new 2008 S302 Extreme will be released at the time of the launch in late summer 2007. As true with all Saleen vehicles, the 2008 Extreme will be fully certified to meet federal safety and emissions standards.
Individuals can go to www.saleen.com/transformers.htm to find more information regarding Saleen’s involvement in “Transformers” and learn about the Saleen Extreme and other Saleen models.
302es motorja lesz több mint 600 LE-vel... :burnrubber:
Hozzászólás Szerző: StangMan » 2007.07.26 23:52
szerintem nagyon kevesen tudnak úgy bánni a karosszéria tuninggal, ahogyan kell... legyen más, de ne legyen harsány, túlzó... Saleen tudja...
Ez a kocsi nagyon jól néz ki, jó a front maszk, a hátsó rész módosítás és a kerekek is, nem szeretem a jelentős karosszéria módosításokat, de ez jó...
a motor pedig magáért beszél :mrgreen:
üvegtető fasza... de mondjuk nekem szinte az összes autóm gyári elektromos-/ napfénytetős volt eddig... ha nem lehet besötétíteni, akkor az annyira nem jó... nagyon tud ám fentről tűzni a nap... :nap:
Hozzászólás Szerző: TomiTomi » 2007.07.26 23:56
Nekem jobban tetszik az eredeti Mustang GT dizájnja. Persze az S302 extreme technikáját nyugodtan alá építhetnék az enyém alá. :sallala:
Hozzászólás Szerző: TomiTomi » 2007.07.27 0:01
:shhh: Asszem azér' ebben a színösszeállításban nem utasítanám vissza. :shake:
Hozzászólás Szerző: TomiTomi » 2007.07.27 0:05
Még egy igen jó képsorozat a filmbeli verdáról:
És a felírat a gépről.
Hozzászólás Szerző: StangMan » 2007.07.27 0:07
"to punish and enslave" :taps: .... khm.... esetleg ez aktuális lenne máshol is :sallala:
Hozzászólás Szerző: TomiTomi » 2007.09.17 21:18
Egy Saleen S28-es kabrio egy Csehországi találkozón:
Hozzászólás Szerző: StangMan » 2007.09.25 0:20
kemény.... tetszik a motorháztető :klassz:
Hozzászólás Szerző: Bandit » 2007.09.25 12:13
StangMan írta:"to punish and enslave" :taps: .... khm.... esetleg ez aktuális lenne máshol is :sallala:
...khmm...
De úgy látom visszatér a teniszütő fejtámla.
Hozzászólás Szerző: LeMans67 » 2007.09.25 12:19
...khmm...
Csak nem :) A bal oldali bukó tartós kivitel is aranyos...
Hozzászólás Szerző: TomiTomi » 2007.09.25 12:20
LeMans67 írta:
...khmm...
Ott egy transformer belsejébe kukucskáltok. :D
Hozzászólás Szerző: TomiTomi » 2007.10.27 10:03
2008 Saleen S281RF Supercharged
100 darabos limitált széria. Csak feketében és szürkében (alloy grey) lesz kapható a piros grafikákkal. A motorja 465 LE-s és az ára 50 000 $ alatt lesz.
ENGINE
* 281 CID (4.6L) 3-Valve SOHC V8
* 465 HP @ 5800 RPM
* 425 lb-ft TQ @ 4000 RPM
* 3.55” x 3.54” Bore & Stroke
* 39 lb/hr Fuel Injectors
* 98 mm MAF
* Port Matched Series VI Integrated Twin-Screw Supercharger
* Dual-Stage Water-to-Air Intercooler System
* Hi-Flow Inlet Tube, Air Box Cover & Filter
* PowerFlash™ Performance Calibration
* 2.5” Stainless Steel Center Exhaust System
DRIVETRAIN
* 5-Speed Manual Transmission with 8.8″ Differential, 3.31:1 Final Drive
* RACECRAFT SUSPENSION
* Linear-Rate, Coil Springs (F/R)
* Sway Bars, 1.38″ with HD Bushings (F), 0.79″ (R)
* Front Struts (N2), Rear Shocks (N2)
* Three-Link, Live Rear Axle with Panhard Rod
INTERIOR
* Leather Performance Driving Seats with Red Stitching
* 6-Way Power Adjustable Driver’s Seat & Power Lumbar
* 6-Gauge Instrument Cluster with 200 MPH Speedometer & MyColor Feature
* Chrome Dash Vent Bezels
* Leather-Wrapped Steering Wheel with Badge
* Leather Shift Boot with Red Stitching
* Leather-Wrapped Billet Shift Knob & Short-Throw Shifter
* Performance Driving Pedals with Driver Foot Brace
* Serialized Dash Plaque
* S281 Floor Mats & Aluminum Door Sill Plates
* Saleen Key Fob
* One-Touch Up/Down Power Windows
* AM/FM/CD Sound System
* Two Power Outlets
* Variable-Speed Windshield Wipers
* Air Conditioning
* Rear Window Defroster
* Dual Power Side-View Mirrors
* Saleen/Eagle One Detail Kit
* Owner’s Document Portfolio & Warranty Guide
BRAKING SYSTEM
* Power Assisted 4-Wheel Disc Brakes with ABS
* 12.4” Vented Front Disc Brake System
* 11.8” Vented Rear Disc Brake
WHEELS & TIRES
* 20” Chrome Finished Alloy, 7-Spoke Wheels
* High Performance Dunlop Tires
* Tire Pressure Monitoring System
EXTERIOR
* Injection Molded Thermoplastic Olefin (TPO)
* Front & Rear Fascias
* Injection Molded TPO Side Skirts & Door Cladding
* Front Grille
* Integrated Front Turn Signals
* Rear Center Body Panel
* Rear Spoiler & End Caps
* S281 Supercharged Graphics & Identification
* RF Red Saleen Windshield Graphic
* RF Red Saleen Bumper Insert
* RF Red Serialized Front Bumper
* Serialized Engine Bay Plaque
* Championship Wreath Graphic
SAFETY & SECURITY
* Dual-Stage Airbags
* Driver’s Seat Position Sensor
* Crash Severity Sensor
* Lower Anchors & Tethers for Children (Latch) Safety Seats
* Remote Keyless & Illuminated Entry System
* 3-Point Safety Belts for All Seating Positions
* Side-Impact Door Beams
COLOR COMBINATIONS - Exterior Color/Graphic Color/Wheel Color
* Black Clearcoat/Red/Chrome
* Alloy Clearcoat Metallic/Red/Chrome
GENERAL DIMENSIONS & CAPACITIES (COUPE)
* Vehicle Weight: 3620 lbs
* Weight Distribution: 53/47 (F/R)
* Wheelbase: 107.10 in
* Track: 62.8 in/63.9 in (F/R)
* Width: 74.0 in
* Length: 189.1 in
* Height: 56.0 in
* Trunk Space: 13.1 cu ft
* Fuel Capacity: 15.7 gal
Hozzászólás Szerző: StangMan » 2007.10.27 10:10
mintha nemrégiben szó lett volna erről angol nyelvesdirőőő.... :roll:
nem csak copy/paste-elünk :nem: ;)
amúgy jól néz ki... mondjuk a kerekeket nyomnám sérőból matt feketére, mint a Transformers autókon...
