Visszahívások
Re: Visszahívások
Hozzászólás Szerző: TomiTomi » 2012.05.11 10:12
Ford visszahív 10 500 F-150, Mustang, expedition és Lincoln Navigator kocsikat
Az oka egy hibás automata váltó szenzor. Az érintett kocsik: 2011 és 2012-es F-150, 2012es Expedition és Lincoln Navigator, és 2012-2013 Ford Mustang
Report Date : May 10, 2012 at 09:46 AM
NHTSA CAMPAIGN ID Number: 12V190000
Vehicle Make / Model: Model Year(s):
FORD / EXPEDITION 2012
FORD / F-150 2011
FORD / F150 2012
FORD / MUSTANG 2012-2013
LINCOLN / NAVIGATOR 2012
Manufacturer: FORD MOTOR COMPANY Mfr's Report Date: APR 30, 2012
NHTSA CAMPAIGN ID Number: 12V190000 NHTSA Action Number: N/A
Component: EXTERIOR LIGHTING:BACK UP LIGHTS
Potential Number of Units Affected: 10,500
Summary:
FORD IS RECALLING CERTAIN MODEL YEAR 2011-2012 FORD F-150, 2012 EXPEDITION AND LINCOLN NAVIGATOR, AND 2012-2013 MUSTANG VEHICLES, FOR FAILING TO COMPLY WITH THE REQUIREMENTS OF FEDERAL MOTOR VEHICLE SAFETY STANDARD NOS. 102, "TRANSMISSION SHIFT LEVER SEQUENCE, STARTER INTERLOCK, AND TRANSMISSION BRAKING EFFECT" AND 108 "LAMPS, REFLECTIVE DEVICES AND ASSOCIATED EQUIPMENT." THESE VEHICLES MAY HAVE A TRANSMISSION RANGE SENSOR (TRS) THAT WAS CALIBRATED OUT OF SPECIFICATION FOR REVERSE GEAR.
Consequence:
IF THIS CONDITION EXISTS, THE TRANSMISSION MAY NOT GO INTO REVERSE OR WHEN THE DRIVER PUSHES THE SHIFT LEVER IN THE REVERSE "R" POSITION AND THE VEHICLE'S TRANSMISSION DOES GO IN REVERSE, THE "R" MAY NOT ILLUMINATE ON THE DASHBOARD OF THE F-150, EXPEDITION, OR NAVIGATOR MODELS AND/OR THE BACKUP LAMP ON THE REAR OF THE F-150, EXPEDITION, NAVIGATOR, OR MUSTANG VEHICLES MAY NOT ILLUMINATE. THESE CONDITIONS INCREASE THE RISK OF A CRASH OR A PEDESTRIAN BEING STRUCK DUE TO THE VEHICLE'S NOT SIGNALING IT IS IN REVERSE.
Remedy:
FORD WILL NOTIFY OWNERS, AND DEALERS WILL INSPECT AND REPLACE THE TRS AS NECESSARY, FREE OF CHARGE. THE SAFETY RECALL IS EXPECTED TO BEGIN ON OR ABOUT JUNE 25, 2012. OWNERS MAY CONTACT FORD MOTOR COMPANY CUSTOMER RELATIONSHIP CENTER AT 1-866-436-7332.
Notes:
FORD'S RECALL CAMPAIGN NUMBER IS 12C23. CUSTOMERS MAY CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION'S VEHICLE SAFETY HOTLINE AT 1-888-327-4236 (TTY: 1-800-424-9153); OR GO TO HTTP://WWW.SAFERCAR.GOV" onclick="window.open(this.href);return false;.
Re: Visszahívások
Hozzászólás Szerző: TomiTomi » 2013.01.31 10:15
Ford visszahívja némely 3,7 l-es V6-os 2013as Mustang-ot
Környezetvédelmi visszahívás, szoftverfrissítéssel javítják.
Részletek itt.
Re: Visszahívások
Hozzászólás Szerző: TomiTomi » 2014.12.25 18:27
Takata légzsák miatt nagyon sok Fordot visszahívtak az USÁban. A legfrissebb:
FORD EXPANDS TAKATA DRIVER-SIDE AIRBAG INFLATOR SAFETY RECALL
DEC 18, 2014 | DEARBORN, MICH.
At the request of the National Highway Traffic Safety Administration, Ford is expanding its recall on Takata driver-side airbag inflators. This recall includes approximately 502,489 vehicles, an addition of approximately 447,310 vehicles.
This brings the total number of Ford vehicles being recalled for Takata airbag inflators to approximately 538,977.
This expanded recall includes 2005-2008 Ford Mustang vehicles built Aug. 18, 2004 to June 25, 2007 at Flat Rock Assembly Plant and 2005-2006 Ford GT vehicles built Feb. 11, 2005 to Jan. 30, 2006 at Wixom Assembly Plant.
As of Dec. 18, 2014, Ford is aware of approximately 462,911 vehicles in the United States and federalized territories, approximately 27,516 in Canada and approximately 7,578 in Mexico affected by this recall. Approximately 4,484 additional vehicles outside of North America are also included in this action.
Ford is aware of one accident with an injury that may be related to this condition. Dealers will replace the airbag inflator at no cost to the customer.
Re: Visszahívások
Hozzászólás Szerző: TomiTomi » 2015.01.10 15:22
Ezen a linken meg tudod nézni, hogy a kocsid érintett-e valamilyen visszahívásban:
https://owner.ford.com/tools/account/ma ... calls.html
(Betettem az első hozzászólásba is, ott könnyebb lesz a jövőben megtalálni.)
És persze érintett vagyok. :nemtom:
Re: Visszahívások
Hozzászólás Szerző: TomiTomi » 2015.03.03 21:04
Svájcban az a pletyka terjeng, hogy 2015 3. negyedében intézik az Európában forgalomba állított Mustangok visszahívását.
Érint még valakit rajtam kívül itt a fórumban?
dooky
Csatlakozott: 2015.04.22 15:47
Re: Visszahívások
Hozzászólás Szerző: dooky » 2015.04.27 16:49
TomiTomi írta:Ezen a linken meg tudod nézni, hogy a kocsid érintett-e valamilyen visszahívásban:
http://owner.ford.com/servlet/ContentSe ... ecallsPage
En is, de fogalmam sincs, mit kellene tenni:(
Re: Visszahívások
Hozzászólás Szerző: TomiTomi » 2015.04.28 9:01
Még Svájcban beszéltem egy szervizzel, mert mikor ez kiderült, ott volt forgalomba helyezve a kocsim. Ott ígérték, hogy behívják a Mustangokat. Persze azóta az enyém is magyar, így ők aligha fognak értesíteni. Futok itthon egy kört, jó lenne tudni, hogy hányunkat érint.
Re: Visszahívások
Hozzászólás Szerző: TomiTomi » 2015.05.07 20:49
Hárman már tuti vagyunk:
dooky
vaddiszno007
Re: Visszahívások
Hozzászólás Szerző: TomiTomi » 2015.05.22 15:39
Totalcar is rákattant a témára:
Dagad a légzsák-botrány. Az Ön autója is érintett? Most kiderítjük – percről percre
Minket érintő részek:
13:28
Ford. Magyarországon nem adtak el a visszahívásban érintett autók közül egyet sem hivatalosan. Aki mégis másodkézből és/vagy szürkeimporttal jutott hozzá egy-egy 2004-2008 között gyártott Mustanghoz vagy GT-hez, annak fél órán belül közzétesszük azt a VIN-ellenőrzőt, amely úgy Amerikai mint az Európai piacon árult autókat ie lekérdezi a központi rendszerből és jelzi, ha hiba van. Ettől függetlenül jó ötlet lehet felkeresni a márkaszervizt, Mustang-tulajok.
14:46
Ford-update (most kaptam frissiben a márka műszaki igazgatójától):
Az ügyfeleket érintő akciók értesítési rendje a megszokott módon, hosszú idő óta a következőképpen alakul:
Az Európában eladott (és ezáltal típusbizonyítvánnyal ellátott és természetesen erre a piacra készített) autók szervizfüzetében megtalálható egy webcím ahol az autók bármilyen akcióban való érintettségét megtalálhatják. Alapvetően az eladáskor rögzített és új tulajdonos esetén módosítható, Fordos adatbázis alapján 2 alkalommal küld az akcióról értesítést az ügyfeleknek a Ford.
Ez itt egy egészen elképesztően jó VIN-check, még hírszerkesztőnk öreg Escortjáról is mindent megtalált.
Itt több nem európai akciót is meg lehet találni, de az elsődleges célja az erre a piacra készített autók azonosítása.
Az amerikai piacra készült autókat ezen a linken lehet ellenőrizni.
A Takata ügyben európai érintettségről nem tudunk a tegnapi adatok alapján, aki a fenti VIN-ellenőrzés után mégis úgy látja, hogy érintett autóval rendelkezik, az keresse fel a legközelebbi márkaszervizünket.
Szerintem jövő hét elején megnézem a kedvenc márkaszervizem és megkérdem, hogy mit mond erre.
dooky
Re: Visszahívások
Hozzászólás Szerző: dooky » 2015.05.28 9:03
Tomi, ha hallassz valamit, szolj mar ram, pls.
Re: Visszahívások
Hozzászólás Szerző: TomiTomi » 2015.05.28 14:32
Kicsit csapkodnak a hullámok körülöttem, de igyekszem beszélni velük.
Re: Visszahívások
Hozzászólás Szerző: TomiTomi » 2015.06.08 11:51
Ma bent voltam a Kerepesi úti Petrányinál. Felvették az adataimat, meg az autóét és az importőr megrendeli a légzsákot az USÁból és szólnak, hogy mikor lehet menni a garanciális cserére.
Ha nincs kedvenc Ford szervized, akkor tudok elérhetőséget adni ahhoz az emberhez, aki az enyém adatait felvette. Ő már elvileg tudja, hogy mi a teendő.
dooky
Re: Visszahívások
Hozzászólás Szerző: dooky » 2015.06.10 8:31
Pls Tomi, add meg...gondolom igy is kicserelik, hogy szurken jot be az orszagba
Re: Visszahívások
Hozzászólás Szerző: TomiTomi » 2015.06.10 8:43
Azt mondta nekem a szervizvezető, hogy garanciálisan cserélik a visszahívás miatt, csak sokáig tart még ideér az alkatrész. (Légzsákot nem küldhetnek repülőn...)
A telefonszám megy PÜben.
Ezzel a linkkel bizonyítottam neki, hogy beleesik a visszahívásba a kocsim: http://owner.ford.com/servlet/ContentSe ... ecallsPage
dooky
Re: Visszahívások
Hozzászólás Szerző: dooky » 2015.06.10 13:05
TomiTomi írta:Azt mondta nekem a szervizvezető, hogy garanciálisan cserélik a visszahívás miatt, csak sokáig tart még ideér az alkatrész. (Légzsákot nem küldhetnek repülőn...)
Egyebkent nem az egesz legzsakot cserelik, csak a pyropatront es fogalma sincs mikorra lesz meg az alkatresz, de az enyemmel egyutt rendelte a tied, ergo meg meg sem rendelte eddig;-)
