2015 Ford Mustang Recalls / visszahívások
Hozzászólás Szerző: kopaszkrapek » 2016.10.27 17:00
LATCHES/LOCKS/LINKAGES:DOORS:LATCH
NHTSA CAMPAIGN ID: 16V643000
RECALL DATE: 2016-09-06
SUMMARY
Ford Motor Company (Ford) is recalling certain model year 2012-2015 Ford Focus, 2013-2015 Ford Escape and Ford C-MAX, 2015 Lincoln MKC and Ford Mustang, and 2014-2016 Ford Transit Connect vehicles. A component within the door latches may break, preventing the doors from latching and/or leading the driver or a passenger to believe a door is securely closed when, in fact, it is not.
CONSEQUENCES
A door that is not securely latched could open while the vehicle is in motion, increasing the risk of injury to a vehicle occupant.
REMEDY
Ford will notify owners, and dealers will replace the door latches with an improved part, free of charge. Due to a limited parts supply, each owner was mailed an interim notification beginning onOctober 3, 2016 and will receive a second notice when parts are available in the second quarter of 2017. Owners may contact Ford customer service at 1-866-436-7332. Ford's number for this recall is 16S30.
A hozzászólást 1 alkalommal szerkesztették, utoljára kopaszkrapek 2016.10.27 17:07-kor.
Re: 2015 Ford Mustang Recalls
Hozzászólás Szerző: kopaszkrapek » 2016.10.27 17:02
SERVICE BRAKES, HYDRAULIC:FOUNDATION COMPONENTS:DISC:CALIPER
NHTSA CAMPAIGN ID: 15V832000
RECALL DATE: 2015-12-10
SUMMARY
Roush Performance Products, Inc. (Roush) is recalling certain model year 2015 Ford Mustang GT Roush Stage 3 vehicles manufactured April 1, 2015, to October 31, 2015, and equipped with Roush Extreme Duty Half Shafts. The affected vehicles have a brake caliper guide pin that may not have been sufficiently tightened during installation of the half shafts. As a result, the caliper guide pin may loosen while driving, reducing the vehicle's rear braking ability.
CONSEQUENCES
A partial loss of the rear braking system can increase the risk of a crash.
REMEDY
Roush will notify owners, and Roush-authorized Ford dealers will tighten the caliper guide pin to the proper specification, free of charge. The recall began in February 2016. Owners may contact Roush customer service at 1-800-597-6874.
Hozzászólás Szerző: kopaszkrapek » 2016.10.27 17:03
FUEL SYSTEM, GASOLINE:STORAGE:TANK ASSEMBLY
NHTSA CAMPAIGN ID: 15V339000
RECALL DATE: 2015-06-02
SUMMARY
Ford Motor Company (Ford) is recalling certain model year 2015 Ford Mustang vehicles manufactured February 14, 2014, to February 10, 2015, and equipped with 2.3L engines. Prolonged exposure to elevated underbody temperatures can cause degradation of the fuel tank and/or fuel vapor lines, which may eventually result in a fuel leak. In addition, this condition could cause seals in the parking brake cable to degrade, potentially affecting parking brake function.
CONSEQUENCES
If the vehicle experiences a fuel leak in the presence of an ignition source it can, increase the risk of a vehicle fire. Reduced parking brake function could potentially result in unexpected vehicle movement, which may increase the risk of injury.
REMEDY
Ford will notify owners, and dealers will replace the fuel tank shield, add thermal patches to the fuel tank and parking brake cable, and add thermal wraps to the fuel vapor lines. The repairs will be performed free of charge. The recall began on July 9, 2015. Owners may contact Ford customer service at 1-866-436-7332. Ford's number for this recall is 15S19.
A hozzászólást 1 alkalommal szerkesztették, utoljára kopaszkrapek 2016.10.27 17:06-kor.
Hozzászólás Szerző: kopaszkrapek » 2016.10.27 17:04
NHTSA CAMPAIGN ID: 14V774000
RECALL DATE: 2014-12-05
SUMMARY
Ford Motor Company (Ford) is recalling certain model year 2015 Ford Mustang vehicles manufactured September 25, 2014, to October 9, 2014. The fuel pressure sensor may not have been seated properly to the fuel jumper line, which may cause a fuel leak.
CONSEQUENCES
A partially seated fuel pressure sensor could cause a fuel odor or a fuel leak, increasing the risk of a vehicle fire in the presence of an ignition source.
REMEDY
Ford will notify owners, and dealers will replace the fuel jumper line, free of charge. The recall began on December 17, 2014. Owners may contact Ford customer service at 1-866-436-7332. Ford's number for this recall is 14S27.
Hozzászólás Szerző: kopaszkrapek » 2016.10.27 17:05
SEAT BELTS
NHTSA CAMPAIGN ID: 14V649000
RECALL DATE: 2014-10-17
SUMMARY
Ford Motor Company (Ford) is recalling certain model year 2015 Ford Mustang vehicles manufactured August 18, 2014, to October 2, 2014. In the affected vehicles, the passenger safety belt tension sensor may misclassify the size of the front passenger seat occupant. This could cause a child size occupant to be classified as an adult and an adult passenger to be classified as a child passenger. As such, these vehicles fail to comply with the requirements of Federal Motor Vehicle Safety Standard No. 208, "Occupant Crash Protection."
CONSEQUENCES
If the tension sensor misclassifies the front passenger, improper passenger air bag deployment may occur, increasing the risk of occupant injury in the event of a vehicle crash.
REMEDY
Ford has notified owners, and dealers will replace the passenger safety belt buckle, free of charge. The recall began on October 28, 2014. Owners may contact Ford customer service at 1-866-436-7332. Ford's number for this recall is 14C08.
Re: 2015 Ford Mustang Recalls / visszahívások
Hozzászólás Szerző: TomiTomi » 2016.10.29 15:33
Kösz. :klassz:
Mivel a legtöbb visszahívás több típust érint, így ide szoktam tenni a visszahívásokat: http://www.ford-cruising.hu/forum/viewt ... ?f=6&t=150" onclick="window.open(this.href);return false;
