![Szomorú :(](./images/smilies/icon_sad.gif)
Ehhh. Kár érte ![Szomorú :(](./images/smilies/icon_sad.gif)
Ő teljesen jól néz ki
http://www.v8cars.hu/hirdetes.php?apro=559a8a0108768" onclick="window.open(this.href);return false;
- Silver Ghia
Mi volt ez?GTPeti írta:Ő teljesen jól néz ki
Törölt hirdetés.
92-es Caprice
Ismét egy "szakértő".
Sor 4-es GT-Cobra Fox body
http://www.hasznaltauto.hu/auto/ford/mu ... ra-9162855" onclick="window.open(this.href);return false;
![Hülye :hulye:](./images/smilies/hulye.gif)
Azt hiszem, most záratom ki magam egy életre a fórumból, de ez az átépítés nagyon tetszik! Ha lenne rá lehetőségem, megcsinálnám. (egy USA használtautós oldalon találtam).
1994 Mustang - v6 titled car
6.0 LQ9 engine, new rings, rod, main and cam bearings, china head studs, trunion upgrade, TSP dual springs, comp pushrods, custom Bullet nitrous cam, ls2 intake, 90mm cable throttle body
4L60E fresh rebuild - upgraded clutches, band, sunshell, valve body mods, circle D custom converter, aluminum driveshaft, stealth ratchet shifter
8.8 rear - freshly built, 3.73 gears, yukon diff, 31 spline axles
Steeda double adjustable upper rear control arms, custom tubular/heim joint lower control arms, koni double adjustable coil over rear shocks
Maximum Motorsports tubulat k-member and control arms, bump steer kit, adjustable QA1 coil over front struts, MM caster/camber plates
cobra brakes front and rear
03 cobra wheels
custom 4130 6 point roll bar
aluminum radiator and electric fan
Aeromotive 340 fuel pump, corvette filter/regulator, all an/braided steel hoses and fittings, fast fuel rails
Super fun car you can drive anywhere, runs 11.1 on motor and gets 26 mpg. Nitrous kit not included, but ran 10.1 on a 125 shot. Selling because I started another project.
https://www.youtube.com/watch?v=L8TPo7C6wG0" onclick="window.open(this.href);return false;
$10500, priced to sell, located near St.Louis, MO
Text (314)420-1321 with inquiries
03 cobra wheels
Az ara szerintem majdnem realis...Silver Ghia írta:2006 Mustang, V8 kézi váltóval:
http://www.hasznaltauto.hu/auto/ford/mu ... v8-9136419" onclick="window.open(this.href);return false;
Csak piszkálta a csőröm az autó. Megpróbáltam felvenni a kapcsolatot az eladóval. Eltelt pár nap, válasz nem jött, de a hirdetést leszedte.Silver Ghia írta:Ennek nem a csapágy a legnagyobb baja, azt olcsón lehet javítani.
A jobb oldala ennek telibe volt verve, a küszöbtől kezdve a B oszlopon át a két ajtóig minden kuka.
Valahogyan összegányolták, de lehet a váz is elment.
Nem véletlen hogy csak balról van fotózva.
Ezek szerint valaki szerencsétlen megvette.
És a legújabb gyöngyszem:
"eredeti állapot, soha nem volt felújítva".
Csak érdekelne, hogy meiyik eredeti 65-ös Mustang volt 467 lóerős és ipari porszívóból formázott műanyag hood scooppal ellátott
http://www.hasznaltauto.hu/auto/ford/mu ... ck-9172777" onclick="window.open(this.href);return false;
Ezzel a kocsival sok gond van. A legnagyobb, hogy ha valaki nem ért hozzás és megveszi egy életre elmegy a kedve a Mustangozástól és a veteránozástól is, mert soha nem tudja forgalomba helyezni.
![Szégyeli magát :oops:](./images/smilies/icon_redface.gif)
![Mustang :stang:](./images/smilies/pimpedstang.gif)
Ebben mi az akció??????????
http://www.hasznaltauto.hu/auto/ford/mu ... ng-9181888" onclick="window.open(this.href);return false;
Mitől egyedi?Az árától?
És ezt valaki ismeri, van valami infótok?
Hát igen ha tényleg kitűnő az állapota 5 körül reálisabb lenne.dooky írta:Az ara szerintem majdnem realis...Silver Ghia írta:2006 Mustang, V8 kézi váltóval:
Nem tudom, én 5-ért nem adnám oda. Annyiért adjak a külföldi papírosokat, de magyarral azért több ettől...pfantom írta:Hát igen ha tényleg kitűnő az állapota 5 körül reálisabb lenne.dooky írta:Az ara szerintem majdnem realis...Silver Ghia írta:2006 Mustang, V8 kézi váltóval:
Ezt látni kéne mert így láthatatlanban nehéz. Meg hát kinek mi a kitűnő állapot.
Sajnos vannak akik elrugaszkodnak az árral,pedig az autó mesze nem olyan mint aminek leírjak.
Nem vagyunk egyformák.
Persze ha egy kis tuniningot is akarsz fék,felni akkor már ott vagyok hogy megveszem ezt.
http://www.hasznaltauto.hu/auto/ford/mu ... es-8993375" onclick="window.open(this.href);return false;
Erre már nem kéne költeni semmit, mert ez így jó ahogy van. És itt már jóval többet kapok extrában és teljesítményben is.+ a 6 év
Szóval az a 5,9 mill durvának találom nagyon.
Piac és kereslet eldönti. 5,3 5,2 ha tényleg kitűnő. Én többet nem adnák érte.
![Ördögi :ordog:](./images/smilies/evil.gif)
- Silver Ghia
Ezzel pusztán egy gondom van, hogy a Csonticar-tól lett véve!pfantom írta: http://www.hasznaltauto.hu/auto/ford/mu ... es-8993375" onclick="window.open(this.href);return false;
![Fütyörészik :sallala:](./images/smilies/sallala.gif)
